292 fiberglass issues >
Old 06-05-2005 | 09:49 PM
smokinh2o's Avatar
Default 292 fiberglass issues
I have a 2002 - 292 fastech purchased new in April of 2004 and have only had this boat on LOTO. While cleaning today I noticed a spider crack about 3" in dia on the vertical surface just behind the mid port side cleat. Has anyone else seen a similar type crack in this location on either side? I just thought it was odd for the gel coat to crack in this location. To a point, I was a bit alarmed because this is an area of the boat where it seems a tremendous amount of stress can occur when hitting waves and I hope the cracking isn't a result of the pounding. Don't know if it's been seen before in similar size and style of boats. Any input on this issue and a recommendation on fixing would be appreciated. Also, does Formula carry any type of warranty beyond 1 year for this type issue? I looked in the Formula Guard booklet and found only items related to mechanical component type failures such as engines, outdirves, etc.
Aaron
smokinh2o is offline
Old 06-06-2005 | 07:30 AM
From: A tree somewhere in the woods in Clarcona Fl.
Default Re: 292 fiberglass issues
Just traded in an 02 292 fastech and saw none of the above cracks/issues.
Are you sure that there hasn't been some sort of an impact in that area?
Slick02 is offline
Old 06-06-2005 | 01:39 PM
Bikini Bottom's Avatar
Mine is 4.0 and it has seen 80 hours of moderate to heavy use. It's a real solid boat. I concur with Slick, any chance of impact damage there?
Bikini Bottom is offline
Old 06-06-2005 | 07:49 PM
smokinh2o's Avatar
Highly unlikely it was impacted in that area because it is not exposed. It's between the cleat and the windshield and below the snaps. You can't hardly get your fingers back in that area when cleaning. The cleat covers up 1/2 to the bottom 1/3 of the area. I've attached a pic of the general area.
Aaron
Old 06-07-2005 | 07:44 AM
Possibly had it docked and a large wake left it with to much weight/stress put on that cleat....I don't know, just making educated guess'es.
Slick02 is offline
Old 06-07-2005 | 08:23 AM
Aaron,
I'm stumpped. Unless the cleat somehow caused it, which would take a ton of pressure on it, I don't see why it would spider. I'd see what Formula thinks...I bet they'd want to fix it and see if they could figure out what happened. Good luck & keep us info'ed.
Old 06-07-2005 | 09:19 PM
smokinh2o's Avatar
Thanks for the input guys. I'll be calling in the next couple of days.
Old 08-14-2005 | 05:45 PM
goldenruhl's Avatar
I have a 2002 292 also. No cracks in 100 hours. I'm thinking leftover 2002. You purchased in 2004. A long time to sit in the dealers lot. What you have could have started on th e dealers lot! Mine was a 1 year leftover and it was supposed to be new. I got it home and found in the correct sunlight I could see where they had stuck letters on the back end that advertised their shop!! Also fould cauliflower under the step in the cuddy - customers - I think not. You just do not know. Personally I would take it to someone who works on Vettes. Fussy customers like boaters.
Good luck,
Rick
goldenruhl is offline
nova26
07-18-2008 09:05 AM
Treads
12-14-2007 10:55 AM
zoomer
01-28-2005 08:55 AM
MY OBSESSION
1
06-29-2003 07:40 PM
MY OBSESSION
06-28-2003 01:11 PM
