-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   What is the middle drain plug for? (https://www.offshoreonly.com/forums/formula/126512-what-middle-drain-plug.html)
Grog 04-02-2006 11:22 PM
On my 1999 271 Fastech, I have three drain plugs. The two outside plugs obviously drain the bilge. What is the middle plug for? Nothing more than a few drops has ever come out of it. The back side of the plug tube is hard packed with foam. The scary thing is that when I stick a metal rod into the foam and pull it out, it is wet. Any ideas???
Rippem 04-02-2006 11:32 PM
Re: What is the middle drain plug for?
drains the grid I believe.
HiPerf2000 04-03-2006 07:35 AM
Thought that was for an optional oil pan drain hose ??
Grog 04-03-2006 12:55 PM
Any idea on how water gets into the grid in the first place?
Rippem 04-03-2006 02:06 PM
don't think it's "supposed" to get in there, under the "pultrusions" that make up the matrix, but "just in case" there is a drain.
Mr Nelems...correct me if I'm wrong?
Grog 04-03-2006 02:37 PM
Thanks Rippem.
Mr. Nelems....agree?
