382 Prop info
I run four blade 28 P Bravo props on a 2000 - 382 w/500's. Can others w/382 provide me with what you are running and what kind of performance you are getting (Planning speed, mid & top end) Did you change for a different prop type & or pitch???
Thanks,
JB
Thanks,
JB
Originally Posted by J.B. Marshall
What is cruising & WOT RPM & Speed??? I also have stelling boxes.
Thanks,
Thanks,
Same thing with my motors. I am turning stock 28 Bravo's at 5400 rpm and 84-85 mph with 645 hp N/A Sterlings through Max Machine beefed XR drives and Stellings boxes. Just had some 28 Bravo's labbed in off season but have not run them yet. Anticipating a 300 rpm increase at WOT and 3-4 mph increase in speed.
I'm running a five blade Hydromotive - 29P on my 2004 382. I have an aggressive X dimension, a sportmaster lower unit with extension boxes, 575 SCI's, 5000 rpm - 77-80 mph. (depending on the load) Tried the Bravo 1's-31P (labbed) and I had trouble getting on plain and I lost 2-3 mph on the top end.
