Calling All Older Formula's >
Old 07-27-2006 | 05:09 PM
mopower's Avatar
Toxic FORMULA
Default Re: Calling All Older Formula's
Originally Posted by 245 limited
I thought my buddy was the only one running oil temp and water pressure!!
Nice to keep an eye on everything!!
That way you can find small problems before they become BIG problems .I just fixed a small problem in my starboard engine. Water pressure was down a couple of pounds and oil temp was up about 10*. Now three weeks ago I hit a piece of wood with my LWP and instantly the presure dropped about 3 lbs. Had to pull the drive and back flush from the seawater pump back. I've gotten wood caught in there before. Too many twists and turn to negotiate.
mopower is offline
Old 07-27-2006 | 08:51 PM
Formula Outlaw's Avatar
Kept mine simple. Painted rub rail and hatches white, dropped the silent thunder box for a clean transom, installed EMI Thunder aluminum exhaust systems with Stainless Marine superflapper tips.
Plus way too many coats of wax.....
Formula Outlaw is offline
Old 07-27-2006 | 09:27 PM
formula1's Avatar
Formula Outlaw, 2 questions. One, did you sell your boat?
Two, what did you paint your rubrail with? I was thinking of changing the rubrail out in favor of white with stainless inserts. But, I heard that is a nightmare!
formula1 is offline
Old 07-27-2006 | 09:58 PM
mopower's Avatar
Toxic FORMULA
Yeah , how'd you paint the rail?? I'd like mine to be white too and that sounds a whole lot easier then replacing
mopower is offline
Old 07-27-2006 | 11:02 PM
Killer_TA's Avatar
He used Krylon Fusion paint. Works real good to. I'm doing the rub rail on my 357 with it. First time I have used it on a boat but I have used it on the plastic gas tank of my Tecate even spilled gas on it and its still there.
Killer_TA is offline
Old 07-28-2006 | 08:24 AM
mopower's Avatar
Toxic FORMULA
What type of prep work was done to the rail? TIA
mopower is offline
Old 07-28-2006 | 08:34 AM
Here was my project:
http://www.offshoreonly.com/forums/s...ht=project+311
Made Fairing
Painted rub rails
Custom Paint
Custom Stereo
Let me know if you have questions
Maritime_Eng is online now
Old 07-29-2006 | 12:04 PM
Killer_TA's Avatar
I removed it and just cleaned it with paint thinner.
Old 07-29-2006 | 02:22 PM
cuda's Avatar
1986 302 SR1. 454/420's. I redid the rear seat and sundeck. Installed Gaffrig controls.
Attached Thumbnails Calling All Older Formula's-11-11-005-small-.jpg   Calling All Older Formula's-11-11-004-small-.jpg   Calling All Older Formula's-6-30-004-small-.jpg
cuda is offline
Old 07-29-2006 | 10:08 PM
formula1's Avatar
Don, I just read that whole thread about your 311! WOW! Nice job!
Killer TA, you removed your rubrail and prepped and painted it?
I'm still trying to figure out how Outlaw did his. Someone said he used Krylon Fusion paint. Did he just tape it off and paint it or did he also remove the whole rubrail? Did he use a prep too?
formula1 is offline
