Another 382 question (for trailer boats) >
Old 11-03-2006 | 07:46 AM
t500hps's Avatar
21 and 42 footers
Default Another 382 question (for trailer boats)
For anyone that trailers a 382 could you do me a big favor. I am having a new trailer built and need to know the distance from the transom (NOT the notched area) to the center of the rear axle. Mine is 6 1/2 feet but the trailer has had too much tongue weight. The new builder will adjust the axles as I need them but I'm not sure how far to go with them.
I'm working with a tight indoor garage and need to get this trailer as short as I can. Thanks!!!!!
Russ C.
t500hps is offline
Old 11-03-2006 | 09:45 AM
Charter Member #415
Default Re: Another 382 question (for trailer boats)
The Eagle I have is 5' both my Prestige are 5 1/2'.
Magicfloat is offline
Old 11-03-2006 | 02:34 PM
I had Myco build me a new trailer and it was perfect. Just have them build it and you don't have to worry about any of this. Mine was a 2001 382
bripar77 is offline
Old 11-03-2006 | 04:10 PM
t500hps's Avatar
21 and 42 footers
They make great trailers...a buddy just bought one for a Top Gun.
Since I dunk in salt water and can get an aluminum for 10G's less I'm willing to ask a few questions and get one that is just pretty good instead.
BTW: NICE BOAT!
t500hps is offline
Old 11-03-2006 | 05:46 PM
berns29scarab's Avatar
where are you trying to set your tongue weight at ? how many lbs ?
berns29scarab is offline
Old 11-03-2006 | 06:42 PM
t500hps's Avatar
21 and 42 footers
I thought it should be at 800-900 lbs but the builder said it should be 400-500. Still not convinced it should be that light. I'm not going to have any room to move the boat forward or back once it's done.....unlike someone else I know!
t500hps is offline
Old 11-03-2006 | 07:09 PM
Charter Member #415
400-500# on a 382 you better have a truck like BgChuby If you have what most of us drive you will be crashing before you get to the ramp. Some use a rule of thumb of 10% of total weight.That is a little high maybe but 800-900 should work.1000# would be OK also. Another thing to consider is hitch height. If it's too low the front tires will wear fast. A good adjustable height hitch can make a world of difference
Old 11-03-2006 | 07:43 PM
t500hps's Avatar
21 and 42 footers
From all the cruisers I use to own I have an assortment of various height ball mounts.....Since I'm also shopping for Duallies I'm sticking with the 800-1,000 lbs target.
t500hps is offline
Old 11-04-2006 | 05:54 AM
Right on Magicfloat,But I wonder how good the trailer is if the builder does not know where to set the axles for correct tounge weight.
selpel is offline
Right on Magicfloat,But I wonder how good the trailer is if the builder does not know where to set the axles for correct tonuge weight.
selpel is offline
