-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   242 LS Hull 75+ mph Possable (https://www.offshoreonly.com/forums/formula/146793-242-ls-hull-75-mph-possable.html)
twin242ls 12-13-2006 05:19 PM
Re: 242 LS Hull 75+ mph Possable
Love the squat. If we wanted to look like everyone else we would run bayliners
HTRDLNCN 12-13-2006 06:57 PM
correct prop and in the case of dual motors correct rotation of props should correct any ride problems.
There is no reason a Formila with a staight bottom should porpoise unless something is wrong with the setup.
Prop and drive science has come a long ways since Formula
made them in the 80s.
My lil 21 footer with a 454 and radar arch in the back is very stern heavy. With the wrong prop(bowlifter) it bounces up and down like a carnival ride. With a stern lifting (or no lift) prop it rides smooth as can be.
Originally Posted by mopower
You're absolutely correct but in the case of a 272 with big blocks , it's very stern heavy and tends to porpoise between 40 and 60 mph without using tabs anyway. Removing the hook would only make it worse. Next summer I plan to try some Hydromotive props in lieu of Bravos since B1's are bow lifters anyway and Hydros are stern lifters. A single engine 242 is a bit of a different story as the balance is much better than a twin BB 272 as demonstrated in these pictures.
Cignificant 12-13-2006 08:28 PM
1 Attachment(s)
'89 Formula 242 with single 502ci using a B&M 250 blower. Bravo drive. I can't remember what prop I had on it. Ran 78mph (on hand held GPS) all day long. Sometimes I wish I had it back.
thanks_don 12-31-2006 12:05 PM
1990 242 LS 454 330 bravo drive , ya there's nothing like the 'squat' .. Id like to ad some hp !! :D
cuda 12-31-2006 07:14 PM
1 Attachment(s)
I found that even with twin small blocks, I had to add some weight on the sun deck for the proper squat.:p
thanks_don 12-31-2006 07:34 PM
LOL Cuda just right !
birdog 01-01-2007 06:55 AM
I had a 241 Lib with twins years ago...The Hydros helped mine ALOT. really lifted the stern up at speed.
mopower 01-10-2007 04:30 PM
1 Attachment(s)
Speaking of squat:eek:
masi242 01-11-2007 03:13 PM
1 Attachment(s)
Mopower, I think that`s my old boat:drink:
I need more squat:D
mopower 01-11-2007 09:43 PM
1 Attachment(s)
I need more squat:D
My buddies with 509 is the same:(
