Question about 353 >
Question about 353
Question about 353
Old 01-08-2007 | 08:20 PM
  #31
WAGS382's Avatar
Default Re: Question about 353
Screw the donzi talk and get to the original question.
I have a 382 and I also feel that I need more bow lift at full speed.
The 382 carries the bow fine in the mid range, but at 80+ I feel that it is too low. The prop slip numbers support this theory.
As we put more power to these boats and want to add more pitch we also add stern lift.
Adding pitch and or more blades will lift the stern making the bow drop.
Try running the props inward to see if this gives more bow lift, it worked for me with the 5 blade props.
Jeff
WAGS382 is offline
Old 01-08-2007 | 08:36 PM
  #32
t500hps's Avatar
21 and 42 footers
Jeff
My 382 had so much bow lift I couldn't cruise below 48 on GPS. Anything less and the stern just sunk and had to use some tab.
Motors were 8 PSI Procharged 500's but are going back to N/A 540's this winter. Was spinning 4 blade 34's but willl probably be spinning 30's with about 625HP when finished. Hopefully I will carry the bow close to how it was before.
t500hps is offline
Old 01-08-2007 | 09:18 PM
  #33
Default Re: Question about 382
Hi, guys. did formula use a 2.0 to 1 ratio bravo one behind 502 mags on the 382, if so why. jenks
jenks is offline
Old 01-08-2007 | 09:28 PM
  #34
Charter Member #415
Every 382 I know of is 1.50. There is no 2.00 Bravo 1. You may be thinking of a Bravo 3,available in 2.00,but no 382's ever had B3's.
Magicfloat is offline
Old 09-04-2010 | 10:01 AM
  #35
offthefront's Avatar
bump .....
new question to an old problem ... I wonder if adding the boxes would help the bow lift because of the extra leverage and also your moving a cpl of hundred pounds aft?
offthefront is offline
SeaWeasel
08-09-2007 12:18 PM
nolimits
03-02-2006 09:51 PM
SCARABJ
02-23-2006 06:56 PM
pwrbotr
02-22-2006 09:02 PM
Donzilla
Prop Talk
4
07-13-2005 07:42 AM
