Gauges, senders and bezels OH MY >
Old 01-11-2007 | 09:47 AM
88formula223's Avatar
NO WAKE ENFORCER
Default Re: Gauges, senders and bezels OH MY
thanks guys
Im going to leave them in the same order just drop the hour meter and add a depth gauge there or something
I'm sure its easier to pull the whole panel and remove and replace the gauges out of the dash?
88formula223 is offline
Old 01-11-2007 | 04:53 PM
I had to make a new panel when I change to the Gaffrig. The VDO's had a special ring around the gauge and tha back of the original panel had a machined piece of lexan thaat the VDo gauges twisted inot. Not to mention the holes for the Gaffrig needed to be larger diameter. Quick and dirty is use a piece of starboard while an aluminum panel is made. I measured up my panel from the original and laid it out in Autocad and sent it off to a fabricator for laser cutting, then powdercoated it black.
Treads is offline
Old 01-25-2007 | 07:32 AM
LAKE EFFECT's Avatar
Originally Posted by Treads
I agree with insptech, all I did was cut off the spade ends from the wiring and crimp on ring terminals for the new gauges, couple of hours at best, same on the senders. I dropped out the speedo completely.
When I did my 311 dash, I didnt want to cut all the formula female spade connectors off. Instead I got a hold of MSD and bought a bag of small adapters they use with there ignitions, its a small metal connector with a male spade on one end, bent at a 45, with a #8 hole on the other end. Worked perfect without cutting up the factory wiring.
LAKE EFFECT is offline
Old 01-26-2007 | 02:36 PM
i installed autometer marine & had a new carbon fiber dash panel made
formula 382 sr-1 is offline
Old 01-26-2007 | 02:56 PM
PhantomChaos's Avatar
What is that red plate with the 5 oblong holes? Nice update! Did someone paint that dash black?
PhantomChaos is offline
Old 01-26-2007 | 03:04 PM
Looks like a billet step plate from Trick or Eddie or CP or . . . . F382, I want to know where you got the C/F panel made . . . .
SeaWeasel is offline
Old 01-26-2007 | 04:01 PM
...had a new carbon fiber dash panel made
Really like that carbon fiber panel.
Treads is offline
Old 01-26-2007 | 04:34 PM
step plate from eddie marine had a hole to cover from an old depth finder, carbon fiber panel i had made at norva plastics inc. in norfolk va .i had one made for my 382 also .did the port side dash panel to .the dash was black
Old 01-27-2007 | 09:08 AM
Audiofn's Avatar
Charter Member #232
You can get them all over the internet. Just a FYI with those panels. You have to treat them with UV protectent if they do not already have them on it. Carbon Fiber does not like UV and it will turn to crap in a hurry if not protected.
Jon
Put your best foot forward!
Audiofn is offline
Old 01-28-2007 | 07:25 PM
no problem with UV ,WEB web site www.norvaplastics.com phone # 757-622-9281, my panels are two years old.
