-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Canvas Snap replacements? (https://www.offshoreonly.com/forums/formula/150297-canvas-snap-replacements.html)
Rippem 01-30-2007 04:58 PM
Re: Canvas Snap replacements?
Originally Posted by ThirdBird (Post 2009626)
I personally think the screw'in types are better. As long as the existing hasn't wallowed the hole out too badly
we are talking about canvas here...right 'Bird? :eek: :evilb:
dukenrock 01-30-2007 05:01 PM
Unbelievable! Thanks Robert!!!!!!!!!!!!!!!!!!!!!!!
Originally Posted by Magicfloat (Post 2010327)
Brian and Kevin,your stuff went out today. Mike,you have to wait till after the show for your 22 cent part.:drink: :D
RaggedEdge 01-30-2007 05:22 PM
I personally think the screw in types are better. As long as the existing rivet type has not wallowed the hole out too badly (which they do) then a little 3M 5000 on a screw type will last forever. If the existing hole is in good shape and you're worried about cracking the surrounding gel, just drill the hole accordingly per the screw size. If you put new rivet types in those existing holes, they'll just loosen up again and be worse than now.
Just my .02 on snaps. :cool:
Another trick is to use a counter sink bit and chamfer the edge of the hole, this helps to cut down on the tendency of the screw to crack the gel. Then, as Bird says, a little dab of 3M "5200" to keep it from backing out.
Just adding my $.02 to Birds $.02, now you have the whole $.04 on snaps.
Rippem 01-30-2007 05:25 PM
with masking tape over it first ;)
offthefront 01-30-2007 05:52 PM
:drink:
ThirdBird 01-30-2007 05:56 PM
Yeah, dats da stuff.:D
plumbers crack 01-31-2007 05:45 PM
Thanks Robert,got a call 1st thing from Formula!!!Magic Float your the Bestttttttttttttttt!
Make sure you sell some boats I'm using the sales of high performance boats as a guide when investing.Looks like things are starting to move a little.Good luck at the show.
Brian
dukenrock 01-31-2007 06:19 PM
Majic,
They were on my door step when I came home today. Living next to the factory has it's benefits....so does buying a boat fom the world's best Formula Dealer in the whole wide world!!!!!!:D :drink: Why would anyone ever consider any other dealer...................why, why why why why?????????
