Fuel lines 382 >
Fuel lines 382
Fuel lines 382
Old 01-31-2007 | 11:05 AM
dukenrock's Avatar
Default Re: Fuel lines 382
Rip,
Do you recall the fuel line size? I'm an hour away from the boat and want to pick up some more fuel line and clamps.
dukenrock is offline
Old 01-31-2007 | 04:39 PM
I wanna say 3/8 from the primary water seperator(s) that's back under the floor/backseat behind the tank, but don't want to steer you wrong.
Rippem is offline
Old 01-31-2007 | 04:44 PM
I'm not sure what the flow limitations are of the flowscan units - The largest gas flow sensor I have seen is 45 gph, maybe that is all it will record accurately - you might want to look down the barrel to see if you have a true 3/8" bore. Some of these sensors will create .5 to 1 lbs restirction. from experience a loaded 525 WFO will burn 44-45 gph. If you have bigger you will need more pressure to compensate
Let us know what your specs are, drive and prop and fuel burn
James is offline
Old 01-31-2007 | 05:10 PM
Flo-Scan makes 100 GPH sensors for consumer use, and much larger capacity sensors for the aircraft industry.
I wouldn't question the product too much, it's aircraft quality stuff. They are out of Seattle. What huge industry is right outside of Seattle?
Any idea why planes of many desciptions both civilian and military don't run out of fuel in the air?
It's not because they use the fuel gauges we have in our boats!
I believe he has the 50 GPH sensors.
Rippem is offline
Old 01-31-2007 | 06:34 PM
dukenrock's Avatar
I called Darrell at Formula and he said to get the 1" Adel's. (That's why I wanted the hose size..Guess I could have asked you for the Adel size) Picked up the adels today and will reroute this weekend. Just need to get some more fuel line and I should have everything I need. Thanks for the routing advice. (they are 50gph)
Old 01-31-2007 | 10:15 PM
you know if your over 50gph why count?
jenks is offline
Old 02-01-2007 | 04:44 PM
offthefront's Avatar
I'm using the Russell Nylon Braded hose on my motor rework ...nice stuff and can be reused and easy to remove ....Pricey but nice ..... Black .....
http://russellperformance.com/new/mc...-classic.shtml
offthefront is offline
Old 02-01-2007 | 09:29 PM
dukenrock's Avatar
That's what I was thinking of. I like.
tewks
05-18-2006 10:40 AM
ofshore
2
07-31-2005 09:30 PM
electrical1
11
06-26-2005 11:58 PM
Formula29
12
04-09-2004 11:59 AM
