On my 292, the access is under the rear seat, and an access cover in the floor is right over the sending unit. I believe on the other models (272 and 242) the access is limited, but I don't think you should have a problem on your 311.
Originally Posted by MOERON
(Post 2034853)
Treads,
I had some errors in my last reply! I have heard that the fuel sending unit is hard to get to for replacement, is that true? It came out perfect; looks like a factory access hole. With the seat cushions back on you can't even see the hole. |
When I changed my gauges to Gaffrig on my 311 I was able to pull the old fuel sender out part way then cut it in two and remove it. The new Gaffrig sender did not have the old style float arm and went in with no problem. You do have to run a separate ignition powered wire to the new sender in addition to the original sender and ground wires.
I would appreciate any input from someone who has changed their rub rail to white or white/stainless as to what brand they used. I'd like to change mine but it has to look right and cover where the original was. |
Originally Posted by dgduck13
(Post 2034086)
No not bad at all. This is the product I used:
SSH-75 Hollow Back Half Oval 12 or 16 Ft. 3/4" Width #8 Hole Size If you do try this make sure to get the hollow back inserts. The solid back is almost impossible to bend around the corners of the boat. This stuff was easy. Then all you need to do is go to the hardware store and buy some #8 tapered screws. Don I purchased the stainless online but they emailed me and told me it woukd need to be cut down (6' to 8' sections) and the delivery charge changed alot +$45 did they cut this into smaller sections for you and if so did it still work well? Thanks |
I'm also curious about the rivets instead of screws/bolts on the silent thunder platform. Also the upper section bears all the weight while the bottom just carries water and exhaust. No need for high strength like a hull to deck joint. |
I see the rub-rail hardware is #8 . . . what length? The Fountain dealer at LOTO sells rubrail in 20ft sections and I am going to do mine this spring. So, I gotta buy a couple of pounds of SS . . . but don't know what length to get. Thanks.
(Post 2041512)
Don,
Originally Posted by SeaWeasel
(Post 2041557)
Don,
I got the Stainless you told me to get (hollow back 3/4") what length screws did you use and how did you bend it around the corners (any heat applied) this is thicker than I was expecting. Thanks |
(Post 2046721)
Don,
| All times are GMT -5. The time now is 05:25 AM. |
