Formula 311 Rub Rail replacement? >
Old 03-15-2007 | 06:45 PM
Originally Posted by dgduck13
I used screws that were about 1.5 inches long. Pre drill the rubrail all the way though so the stainless actually mounts to the boat instead of the rubrail. No heat needed it wont do any good. Just use slow and steady pressure to wrap around the corners.
Don,
Do you happen to know the paint code for the color white you used on the rail?
MOERON is offline
Old 03-16-2007 | 08:11 AM
Originally Posted by MOERON
Don,
I have the codes for my old boat, but that was custom painted with a bright white. this color was brighter than what you have. If you are trying to match the original color I would recomend going to an automotive paint supply store and have them use the scaner on the side of your boat. This way you have an exact match.
Don
Maritime_Eng is offline
Old 05-10-2007 | 04:50 PM
88formula223's Avatar
NO WAKE ENFORCER
Depends on what you are trying to do. Are you replacing the rubrail or just installing the S.S. cap?
any pics of just the SS insert over a black rub rail?
do you guys think that would look good on mine being light grey?
if it is in 6 or 8ft sections where do you start the first piece?
thanks
88formula223 is offline
Old 05-10-2007 | 08:20 PM
do you guys think that would look good on mine being light grey/dove?
thanks
I ended up putting the stailless over the factory black rubrail and I think it looks great. I will get pics up after this weekend.
MOERON is offline
Old 05-10-2007 | 10:00 PM
NO WAKE ENFORCER
thanks
Old 05-15-2007 | 04:41 PM
NO WAKE ENFORCER
did you get to your boat last weekend?
thanks
Old 07-23-2007 | 02:53 PM
freddan's Avatar
Moeron,
Do you have any picture of the new rub rail mounted on the boat? Im thinking of replacing my stock rub rail (black).
freddan is offline
Old 07-23-2007 | 06:51 PM
Originally Posted by freddan
Moeron,
I am going down to the boat on Friday i will take some pictures of Stainless over the OEM black rub rail. I think it looks great. You start the first piece on the front bend.
MOERON is offline
Old 08-07-2007 | 04:28 PM
freddan's Avatar
freddan is offline
Old 08-07-2007 | 04:50 PM
Here you go.
MOERON is offline
