-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   shotgun exhaust? (https://www.offshoreonly.com/forums/formula/151977-shotgun-exhaust.html)
cstobe 02-21-2007 09:08 PM
shotgun exhaust?
Is anyone running the drew marine exhaust on their fastecs? I wonder if they are quiet enough at idle to carry on a conversation around the docks? I don't mind them being a little louder than the silent thunder. will they be almost in the water clamping the on to a 6" tip?
Magicfloat 02-21-2007 09:41 PM
I had forgotten they were still around,used them in the mid 80's on my 18 Donzi SBC. Kind of low tech,even back then.A plate with lots of holes,closes with a spring,exhaust pressure opens the plate. Unless they have made some improvements over the years I would think some of the latest Corsa proiducts would make more sense,course it's been over 20 years since I used them.
RaggedEdge 02-22-2007 07:07 AM
Can't help with where they will sit in relation to the water on your hull. I had them on my Velocity with 525 SC's and was very pleased with how they worked. Took noise from 103 db at idle down to 96 db, and did a good job of taking the harsh bark out of the SC engines. They are simple/low tech but work, and caused no loss of top end speed like some of the other brands do. Would buy them again.
