-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   freshwater flush option (https://www.offshoreonly.com/forums/formula/159300-freshwater-flush-option.html)
5PMSMWHR 05-26-2007 06:58 PM
OK, the new to me '02 353 has freshwater flush on the 500s, can I just hook up the hose and crank up the motors? Never had this option before. A little guidance would be appreciated. Thanks in advance.
RaggedEdge 05-26-2007 08:04 PM
Aren't we the smart ones!!! Both have boats and on a perfect day here we sit, you cleaning vynil all day, and I was sanding sheetrock. :stupid:
As for your FW flush deal, you in "theory" should be able to fire them up on the hose, I would check to be sure they are in fact plumbed in and functional before you try this deal. No water for a nano-second, or so :eek: , and your sea water pump impellor is toast. Been there, done that :( , not nice. If you are not sure on your own, have someone check it out for you first.
Maybe I'll go look at mine tomorow :cool:, before I go back to work on the sheetrock.
BTW your paint is the HOT one of the trio!!! :cool:
Magicfloat 05-26-2007 08:49 PM
Factory flush is plumbed before the seawater pump,turn on garden hose and start,sure and simple.
