-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Outdrive trim questions. (https://www.offshoreonly.com/forums/formula/163180-outdrive-trim-questions.html)
FormulaOne 07-11-2007 08:40 AM
1996 271 SR1 w/ Alpha I drives...
The outdrive still trims but the trim gauge doesnt move, or has a very limited range.
Anyone ever have this problem?
Dont know if I will need to replace the sender, which seems more involved and expensive or if it is the gauge itself.
Thanks in advance.
ThirdBird 07-11-2007 10:45 AM
A 1996 271 with Alpha drives?????:confused:
Are ya sure? Most probably Bravos.
Mechanical indicators or stock Mercruiser?
Iggy 07-12-2007 05:04 AM
Most likely it's the sensor on the drive.
Try removing the sensor and turning the center piece by hand while having someone in the boat watching the gauge.
And yeh, I believe he could have Alpha II drives with SBC's.
FormulaOne 07-12-2007 11:41 AM
Brain fart... Yes, Bravo's.
FormulaOne 07-12-2007 11:44 AM
[QUOTE=Iggy;2195146]Most likely it's the sensor on the drive.
[QUOTE]
Thanks, I'll give it a shot this weekend.
