Bravo 3 to a Bravo 1 XR >
Old 09-13-2007 | 04:56 PM
Registered User
Little impute needed;
I have a 93 Formula 252 BR that I plan on making some drive changes to. I am dropping in a 580 hp BB this winter and I am going from a Bravo 3 (1.5 ratio) to a Bravo 1 XR (1.5 ratio). The question I have is; in its present state, when I run flat out with the Bravo 3, with 26p SS props; I am running 4650 rpm’s and 53mph (GPS), on flat freshwater. Changing only the Bravo 3 to a Bravo 1, using a 26p SS prop, will my rpm be greater than, less than or the same as the Bravo 3. My thoughts are that I would actually pull some more rpm’s simply because I will be displacing less water (i.e.: 1 prop working instead of 2) and the engine will gain more power. My buddy thinks it will be the same. Any thoughts or experience? Thanks, pax2you
pax2you is offline
Dave1972
6
03-30-2009 04:06 PM
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
PARADOX
0
02-27-2008 02:31 PM
articfriends
1
07-30-2006 08:10 PM
rslick
13
06-15-2005 11:54 PM
