Silent Thunder help
2 Attachment(s)
Looking for a Silent Thunder Box of 87 to 91 Vintage with the recessed tow eyes like these....
Cal, wish I could help you out, just can't bring myself to take it off. The ST that is. :D
I'm local to the one, was thinking about asking if he wanted to part it out. Let me know if you want me to try and make contact.
Originally Posted by handfulz28
(Post 2321658)
I already spoke to them and all they would do is separate the boat and trailer. Of course you never can tell what a few more months might do. Thank Handfulz28 |
Cal ... someone on here had one never used ....cant remember who though .... I search around when I get to work tonite .....m
Mike , Chuck (C Spray) was giving one away. Problem is it's the later style that is the removable box under the platform:(
http://www.offshoreonly.com/forums/n...reply&p=245789
post #15 ..... posted in 2002 though .... so you gona give it up why you need ANOTHER one? :cool: |
1 Attachment(s)
The higher style has additional clearence in the center for external center mount hydraulic steering to allow to to tilt your drives. Plus the outlets are higher and I want to make it a Thru Thunder like some others have done.
Is it all big block boats that have this platform? I'm not sure how many different SR-1 ST platforms there were/are, but there's at least a few.
1 Attachment(s)
Update on St box.
Talked to my local fiberglass guy and he assured me it would be no problem to shorten the center exhaust pod up to the pipes , glass it and re gel coat it. The box is coming off next Friday and shrinkwrapped Saturday |
Good luck Mo, keep us up to date on the project.
Will do.
I see what you talking about now .... My box is not back on yet ....The mount on the Transom for the Rams is just below the Gasket for the ST and I'm thinking we took some measurements and it was close but would be ok ...cept that just clearance for the mounts ...your saying as the rams come up to trim the will hit the box below the exhaust outlets ?
Well , I'm going to lose from the crease(and pipes) down:cool-smiley-026:
Mine would be SO close I wouldn't be able to tilt the drives above the lowest part of the boat and that is in the straight position. Have the wheel turned and it only gets worse. So if I got into a shallow situation I could be screwed. |
