-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   38 with 496's (https://www.offshoreonly.com/forums/formula/183833-38-496s.html)
ninetym 04-06-2008 07:13 AM
38 with 496's
What speed will a 38 run with that power? What do you guys think the price difference would be for a 95 419 and a 2001 38 fastek with 496 HO. Both compareable in shape. Options also are the same. Thanks in advance Mark
jeff32 04-06-2008 07:23 AM
my guess is 65 with 496's. I'd guess the 2001 would be...10-15 k more than the 95, approximatly...
J.B. Marshall 04-06-2008 11:19 AM
My $.02 is you would be very dissapointed with that engine package... way under powered for a Fastech.
pokerrunboats 04-11-2008 12:57 AM
419 Sr 1
3 Attachment(s)
419 SR 1 with Triple 496 HO
71 MPH running 1:50 Bravo 1 X drives and 26 `lab finished
Bravo One Props
Add Imco Extension boxes with 3 `rise and a Raylar BCK 103 kit 79 MPH running 30 `lab finished Bravo One Props
The old 419 SR 1 had an X Dimension disigned for Mirage Props - The boat likes the boxes with the 3 `rise
With the Raylar kit the boat plans on any two of three engines without a problem
jeff32 04-11-2008 04:45 AM
nice set up!
t500hps 04-11-2008 08:30 AM
No info on the 419 from me but......the 2001 (probably the one in the clasifieds) should run mid/maybe upper 60's. The 382/500EFI boats only ran about 72-74 at their very best.
BTW: Here's a 382 for you to look over
http://www.speedwake.com/newclassifi...uct=591&cat=51
I'm biased thou...it's mine!!!
ninetym 04-12-2008 12:31 PM
That a nice one. If I was to sell mine I sure would be interested in yours.
Back4More 03-17-2009 11:13 AM
I know of an 05 that runs 70-72 with HO's and labbed 26's
GL@PBC 03-17-2009 12:31 PM
I've seen 68 out of the 08 we have i stock.
jody165 03-18-2009 07:05 PM
And there are a few 382's with 500EFI's out here that run 75-77....I know mine does 75 on GPS ... and that's with 5 blade Maximus props which also have great cruise speed. But they had to be tweeked by BBlades to get that out of em. I've learned all 382's are a little different, some get a couple more mph than others with the same equipment and setup. Mine seems about average.
