Hull specs >
Hull specs
Hull specs
Old 05-13-2008 | 04:05 PM
Default Hull specs
Hi all:
My lift installer is asking for the hull specs for my 350 2008. Anyone know where I can find this info?
cmcjo is offline
Old 05-13-2008 | 04:20 PM
FountainDealer.com's Avatar
www.LEGENDMARINEGROUP.com
Formula customer service will have every thing you need 260-724-9111
FountainDealer.com is offline
Old 05-13-2008 | 07:38 PM
Expensive Date's Avatar
I needed the same thing last year called Formula the emailed me the blueprint.I forwarded to staples and they printed it out in blueprint size.Cost like 10 bucks
Expensive Date is offline
Old 05-13-2008 | 07:40 PM
jeff32's Avatar
nice customer support, go for it!
jeff32 is offline
Old 05-13-2008 | 08:53 PM
Charter Member #415
Only company I've dealt with in 42 years with service like this.They would probrably send specs for a 30 year old Formula. I know they sent a friend the specs for his 1988 311last year.Nobody does it better.
Magicfloat is offline
Old 05-13-2008 | 09:23 PM
So true Robert.
ThirdBird is offline
Old 05-13-2008 | 10:33 PM
jeff32's Avatar
they did it for my previous 1985 F 35-7!
jeff32 is offline
Old 05-14-2008 | 09:36 PM
Mentalpause's Avatar
Originally Posted by cmcjo
Hi all:
Sorry, I am going to go another way on my reply. If your lift installer does not know where to go for the specs - consider another lift installer.
At least at LOTO, they would never ask the customer for this information - they know they need to contact the factory for this. Considering your experience so far on this project you may want to question why your installer can't get this info on his own.
Not trying to be negative here - I just think a good installer should know where to get the info.
Mentalpause is offline
Old 05-14-2008 | 09:53 PM
ericaull's Avatar
when I did my lift, I called formula and Chuck Miller sent me the hull blueprints......No problem there!!
ericaull is offline
Old 05-15-2008 | 06:40 AM
C_Spray's Avatar
Diamond Member #001
It's great that Formula is so helpful in situations llike this, but I have to go with Mentalpause on this one. If they can't figure out how to get the hull specifications, are they going to ask you which way to turn the wrenches next?
C_Spray is offline
