I have a 28ZX with scorpions and they run great. 79 on GPS so far. What props were they running on the 292's? And what way did they spin.
Thanks |
Originally Posted by Trueser
(Post 2634433)
Thanks Higher speeds with 30" labbed Bravo One props. I think even 32" Bravo have been used but I am not sure ? Props are spinning out. Gear ratio 1.65:1 Personally I run std. 28" Bravo One props so I have great acceleration but lower top speed (72-75 MPH). I am considering trying higher pitch props, but I am afraid to loose mid range efficiency. Too high slippage in the cruising mid range and the fuel economy is gone, and the cost of gas here is app. 9.5 USD/gallon so I prefer low slippage :) What props are you using ? |
Originally Posted by Phazar454Mag
(Post 2635044)
The 76 MPH is with 29" labbed Bravo One props.
Higher speeds with 30" labbed Bravo One props. I think even 32" Bravo have been used but I am not sure ? Props are spinning out. Gear ratio 1.65:1 Personally I run std. 28" Bravo One props so I have great acceleration but lower top speed (72-75 MPH). I am considering trying higher pitch props, but I am afraid to loose mid range efficiency. Too high slippage in the cruising mid range and the fuel economy is gone, and the cost of gas here is app. 9.5 USD/gallon so I prefer low slippage :) What props are you using ? I run 25 mirage plus. 80.4 gps last run on lake michigan. |
Trueser, what is the gear ratio of your drives?
1.5
Ihave a freind looking a 292 with scorpions, only 61 hours, what kind of rpm are they running, what is the hours till refresh time.
thanks |
Originally Posted by rssteiny
(Post 2821745)
thanks They run @ 5200 NOt sure on the refresh time. |
(Post 2634394)
http://www.mercruiserparts.com/400_scorpion.htm |
| All times are GMT -5. The time now is 12:02 PM. |
