292 with whipples >
292 with whipples
292 with whipples
Old 07-23-2008 | 07:52 PM
Default 292 with whipples
has anyone had the whipple super chargers installed on the 6.2's on the 292? what are the top end gains with his set up, and can these be installed with out killing the reliabilty of the boat
turboz67 is offline
Old 07-24-2008 | 05:57 PM
thanks_don's Avatar
me like it ????
thanks_don is offline
Old 07-28-2008 | 12:56 PM
rhsj2006's Avatar
I spoke with Dustin at Whipple about this a year ago - Was about to pull the trigger and lining up my installation shop when the markets strarted their downturn, so I put the project on hold. Dammit
From what I recall of my conversation Dustin, adding another 150HP per side is easy and the 6.2 should still be reliable. You want more, gonna have to change the exhaust as well. Check the Whipplle Industries website for dyno charts. I thinklow 80s would be your MPH top end, depending on prop and if you change your drive ratio.
You'll need to add oil coolers, but besides that the install looks pretty straightforward.
Running 450+ HP thru the drive is where you'll need to be a little careful - Holeshots and re-entry on a 8000lb boat (7000 dry, add passengers and fuel) could be hard on a standard Bravo 1...
rhsj2006 is offline
gregsweeney
09-11-2009 11:04 PM
thisistank
02-06-2008 11:33 PM
docmanrich37
07-07-2005 06:22 AM
Kato33
Baja
0
09-15-2004 06:15 PM
Quiet Storm
11
05-29-2002 01:22 PM
