242 how to remove tank? >
Old 08-23-2008 | 03:55 PM
Default 242 how to remove tank?
I have to take tank out and am wondering if there are any L brackets under foam at bottom of tank? I pumped out fuel and disconected all lines. I have a excavator and will cut the foam with saw a,d try lifting out
Thanks scott
scottmori is offline
Old 08-25-2008 | 08:23 AM
masi242's Avatar
This not good news, but if you smell gas it`s a must. I am not sure about any other brackets I thought the foam held it in.
masi242 is offline
Old 08-25-2008 | 12:54 PM
well i got the tank out what a pain in the ass!!!! just foam holding it in. it was leaking quite a few small pin holes fyi if you have a aluminum tank be sure to keep checking for leaks. i am having a stainless steel tank fabbed so should be done in 2 weeks. found about 2 gallons of fuel floating under tankwhat a mess cleaned it all out and am letting it dry out till new tank is ready.
scott
Old 08-25-2008 | 02:18 PM
88formula223's Avatar
NO WAKE ENFORCER
my tech that put mine in said it was a bicth to get out, he used a overhead hoist and it was still a mofo.
88formula223 is offline
offthefront
12-02-2007 06:46 AM
jeff32
01-02-2006 08:52 PM
Mike.McT
10-06-2003 01:08 PM
