More Speed Please
I have a 382 Fastech with HP500EFI motors, Silent Thunder exhaust, Bravo One drives and 28p props. This boat is loaded including a generator, so its a bit heavy. All covered by the 5yr Formula Guard Warranty. I am not looking to upgrade the motors at this time (warranty) but I am looking for ways to get more speed out of this boat. Does anyone have any suggestions or positive experiences with the drives or props that may help.
Thanks |
What RPM are you turning with WOT.What top speed. You may consider using mirage prop to get higher top end, and if budget allows a set of extension boxes(approx 8-10K)Boxes will give you around 5-7 mph increase on that hull(I believe).Some more info on the above questions can help pinpoint a solution better. sounds like a great boat I would suggest bieng happy with 75-78mph? MFB
I wonder if the Herring Props would work as well on a Formula as they did on my buddies Cig Top Gun.
more specs
Last sunday my best speed I saw all day was 74mph on GPS but most of the time in calmer water I read 72.5 mph@5100. I am currently running 28p 4blade merc props. I have some performance thoughts, tell me what you guys think.
Remove silent thunder exhaust replace with Teague Captain choice tips. Install lab30p props and turn inside rotation for more lift. Or the Hydro 5 blade Install Imco lowers to lower the x dimension. I would like to install ext. boxes but they are out of my budget and I believe they would add extra weight to an already heavy boat. I would be extremely happy if the boat hit 80 but would be satisfied with high 70's PS: Troutly You are right, they did not offer this warranty until 2001. This boat was purchased direct from dealer inventory, as new, late last year. I was able to weasel that into the deal :D |
Troutly:
Thanks, I will
Troutly
Magicfloat gave me the Tim Allen line
Needs more power He was very informative Thanks |
Hot Water,
I may have missed this in reading the thread too fast (getting close to beer-thirty on Friday), but what altitude are you at? |
Hot Water, I misunderstood you on the phone,you said you had 502's and I assumed you meant 502 MPI's,not HP 500's.But the advice is still the same, you need more power. Boxes are not the way to go,you have to raise the X-dimension and reinforce the transom,very expensive for a marginal gain. Two words from me-Pro Chargers.As far as warranty,anything you do to increase power could void your warranty. But a lot of that would depend on the shop doing the warranty work,I won't get into that here.Our Procharged Formulas have shown tremendous gains. 312with 454mag MPI's, 73 mph to 88 mph, 353 with HP500carbs,82 mph to 98 mph. Never a problem if the installation is done by a competent shop. You willhave to go to 1.36 gears and maybe a prop change.You have to decide how fast do you want to go and how much do you want to spend. everything is a trade off.
Magicfloat
Those are some huge gains
I looked at a Pro Charger setup over the weekend on a twin 500efi at a Pro Charger dealer. It was quite impressive. I am going on a test run today or tomorrow. I'll let you know what I think. Thanks for all your help |
Boilerdaddy
I boat on the Sacramento River Delta in Northern California. This area is all sealevel.
Troutly
Thanks, I will, I want to explore all of my options.
Bob Teague of Teague Custom Marine just put a Whipple setup on a 42' Fountain, he was lake testing it today. I will be talking to him later this week to see what was his impression. |
Here you go..............
1 Attachment(s)
but say "bye bye" to your warranty, and say "hello" to your insurance man (cuz your rates will go up).
Hey Nort you been bussy since I have been there!!!! :D:D
Were those at the show? Man some shaweet lookin mills!!! |
| All times are GMT -5. The time now is 01:17 PM. |
