Need Some Ideal's >
Need Some Ideal's
Need Some Ideal's
Old 10-26-2008 | 09:40 AM
Originally Posted by ThirdBird
Not to but in here but, I think you're entirely correct. However, if there is no discernable "seat of the pants" increase in performance, doesn't really matter, does it?
ThirdBird, thanks for confirming my thoughts regarding O2 sensors.
Oh yea, I agree, if there wouldn't be much to gain, why mess with it? Although, if the engine compartment was holding in a lot of heat from the engines, on paper there appears to be some power that may be felt in the pants.
Using the air density ratio equation [D.R. = (T1+460)/(T2+460)], say you could reduce the air temp going into the engines from 110°F to 90°F on the same day with better ventilation. D.R. = (110+460)/(90+460) = 570/550 = 1.036, or a 3.6% gain in power due to the cooler, more dense air. In my case with twin 320HP engines, that should be around 23HP. Not a whole lot, but maybe worth it(?)
I know going from the hot, humid summer to cool, dry fall days, my rig is consistently 2 mph faster. But that is more than a 20°F change!
4mulafastech is offline
