Formula mystery water leaks !! >
Old 10-26-2008 | 02:45 PM
Default Formula mystery water leaks !!
I found the source of all my water leaks in my 382. It would leak more in rougher water and faster speeds. The swim step supports on the transom are the locations for all the bilge pump through hulls. In rougher sea I run more tab, more tab more splash. I had another boat follow me and he observed large roosts of water blasting the underside of the area that all the through hulls are located. I plugged these with corks and no more leaks. I installed check valves in the bilge pumps to solve this issue. The shower pump also overflows into the front bilge. I installed a check in this line to solve this mystery leak. There ya go.....
fossil fuel is offline
Old 10-26-2008 | 04:21 PM
t500hps's Avatar
21 and 42 footers
I have the same boat.....occasionally have seen the same problem but never tried to track it down. PLEASE post the info on the check valves you used, I need to get a set as well.
t500hps is offline
Old 10-28-2008 | 10:10 AM
what year is your 382? do you have any pics of what you did?
jkelly is offline
Old 10-28-2008 | 05:40 PM
2005. No pics, West marine stocks the checks. The 2 checks for the 1 1/8" bilge pump lines are a grey PVC with 4 ss bolts & nuts. The 3/4" check is a one piece black one for the shower pump. The Grey pvc checks are actually a 1" od. I used some shrink wrap to make them fit 1 1/8". Works great. I would think you would want to mount them as far aft as you can. You may have to remove your engine hatch to get around the back of the headers with both hands for the bilge pumps.
Old 08-16-2009 | 04:17 PM
Default New Info
I had one check stick open and.......more leak. Now I am going to move the thru hulls for the bilge pumps to a better spot up on the vertical transom. BTW I have put on the long merc K tabs..this did aggravate the problem.
PhantomChaos
10-29-2007 05:53 PM
handfulz28
02-11-2007 10:54 AM
TEAMBAJA
09-11-2006 07:30 PM
Jim Young
6
07-10-2005 11:03 AM
cooltoys61
11
04-13-2005 07:00 AM
