speed 271 Fas tech
I test drove a new Nordic 28 Heat a few years ago before I bought a 271 Fastech. The Nordic was a rattle trap. Lots of cheap plastic in the cockpit and it rode terrible compared to the Formula. I would agree however that given equal power, the Nordic will be faster. My 271 ran low 60s with a stock 502 MPI.
wij zijn in het bezit van een Formula 271 met een 496HO. Hiervoor hebben we er een gehad met een 502 erin. Als je vragen hebt......
Groet Jeroen.
we are Dealer for Formula Boats In Essen, Germany and just 80 km from Venlo
we have a new 271 in stock that is now getting dialed in with its new engine
we change the heavy big block to a light weight small block fully aluminium- The engine is based on the Chevrolet LS engine, that is also used in the Corvette
It produces 550 HP and saves almost 300 kg (550 lbs) compared to a 496
on first trial we hit very quick rev limiter at 70 MPH , but I am sure the boat will run in the mid 70 `s when dialed in perfect with props and X Dimension
The X Dimension is now 3 `inch higher and the boat goes easy on plane - thanks to 550 lbs less weight
call us at +49 209 639604
we speak English, German and Dutch
