Shine
#51
Shameless, do you use anything first to get out all the little Micro. scratches before you apply the Wizard Supreme Seal coat. My boat looks pretty good but I'm always looking for more shine
Thanks Propwash
Thanks Propwash
#52
Registered User
Micro Scratches in paint or gel?? Either way, yes.
Also depends on if you are useing a high speed rotary buffer or an orbital. Also depends on if what pads you are using. But Wizards makes varying degrees of compounds for different sevarities of jobs and wether it is paint or gel. Get me a litle more info on what you have and I can help more.
#53
Shameless, your boat and truck look great. I typically do not use rotary buffers I do most everything by hand because the buffers I do have I don't like. ( Maybe it's time for new one). I'm looking at more of a wet look for my white gel which is most of my boat color. I mostly use 3M products for the scratches with a polish sealant made by Bio-Kleen as a top coat. My boat looks good but I'm always looking for maybe a better combination, you Know what I mean? Thanks Propwash
#54
Registered User
Sorry to ask so much for your questions, but it is the best way I can steer you in the right direction.
#55
Shameless, I'm talking about swirl type sratches. I will give Supreme Seal a try, maybe a long with some of there other products. A new buffer might happen too.
Is the Wizard web sight the best place to buy these products from? Thanks for the help. Todd
#57
Registered User
I would say the best place to buy it is right from the MFG. They can do a great job of answering questions too on the phone. Swirls in Gel are tough to remove by hand. I would say, start off with the Supreme seal, put a couple coats on and see where you are, but a machine will really help do the trick with the help of some Finish Cut. www.wizardsproducts.com
Bill
#60
Registered User
A Wizards tip... When apply, wether by hand or machine, apply very thin. As you rub it in, you should see it almost disapear. if youuse more, you are only wasting it. The 12 ounce bottle of Supreme Seal will do a 292 approximately 10-12 times if done correctly with a machine.
