counter rotating alpha drives >
Old 11-26-2008 | 07:10 PM
wayne272's Avatar
Default counter rotating alpha drives
Need some input from the board. I have '86 272LS with 365hp small blocks running 64mph @ 5000rpm in flat water. Drives are alphas (1.5 ratio) spinning 21p Turbo stainless props. Both drives are righthand turning with simrek showers. Would installing a port LH lower give me some more top end? Looking to get a little closer to 70. thanks for any input.
wayne272 is offline
Old 11-26-2008 | 07:18 PM
Charter Member #415
No.Spend your money elsewhere. Counter rotation helps with steering torque and drivability,not speed.
Magicfloat is offline
Old 11-27-2008 | 10:36 AM
Magic, will the counter rotation lift the stern and allow bigger props?
twin242ls is offline
Old 11-27-2008 | 04:49 PM
Charter Member #415
Theorically,yeah,but reality,doubt there will be any difference.
Old 11-27-2008 | 11:56 PM
just use triple widgets magic alphas and hang on!!!!!
phragle is offline
Old 11-29-2008 | 11:30 AM
Try a 23 Mirage 3 blade on that once and if you gain any speed
Car Biz is offline
Old 11-29-2008 | 11:46 AM
your talking about a 24% increase in speed. you not going to do that with props and c/r, you could gain a little if you did it and really played with props, but if your lifting the back end with the props thats going to put a lot more strain on the alpha's. is that flat-flat water?? that would be the most drag, how easily are you pulling 5 grand?
phragle is offline
Old 11-30-2008 | 02:55 PM
wayne272's Avatar
It was real flat water. No chop. It pulls 5000 pretty easily and was trimmed out , but no tab. The props had a couple of dings (I boat in the Great South Bay,which is pretty shallow), and I had them redone, but didn't get to re-test before winterizing.
wayne272 is offline
Old 11-30-2008 | 04:00 PM
sounds ike you need more prop to begin with, so you prolly should figure out where you are, so you can figure out where your going.
phragle is offline
Old 11-30-2008 | 04:58 PM
Get one counter rotation and a set of 23 3 blades from michigan props ( BALISTIC ) and you will see your # !!!
DareDevil is offline
