-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Fastech 271 blowing out prop...New drive?? (https://www.offshoreonly.com/forums/formula/200872-fastech-271-blowing-out-prop-new-drive.html)
jwurl 01-01-2009 05:33 PM
I am looking at upgrading my drive on my Fastech 271. Is there any way to keep the boat from blowing the prop out?.. Do these boats need a shortie drive, drive extention, extention box???? There must be a way to help or stop this problem???? Any ideas??? Thanks, Jeff
FRMULTR 01-02-2009 06:54 AM
This is the first time I've heard of this problem. What type of prop are you running?
jwurl 01-02-2009 07:49 PM
Search previous posts..All the 271 do this. I have run Bravo 24-26-28's and even a 5 blade Maximus 24. Jeff
tony manzella 01-03-2009 08:21 AM
Blowing out !
Where are you starting out with your drive half way, or down & in, then come up with the drive, what about your tabs where are they set & what kind , you dont say what ratio the drive is or the power your running, alot of things are dependent on what you have , tell the hole story then we might be able to help! :cool:
jwurl 01-03-2009 10:47 AM
2000 271...Starting out - Drive all the way down and tabs all the way down....Engine is 502 MPI with minor mods. 450HP...Drive ratio is 1.65. .. Thanks, Jeff.
Magicfloat 01-03-2009 11:57 AM
This may not be a factor since you probralby have Bennett tabs,but with K-planes,if you drop them all the way down it can cause turbulance and venilate the prop.Just a thought.
