382 winterizing
Antifreeze through the engines after getting it up to operating temp on the hose.....empty the fresh water tank, then pour 2 gallons pink antifreeze in the water system and run through all the hoses (don't forget the transom shower). same with the holding tank, empty, then 2 more gallons of antifreeze in there....A/C system, need to get if fired up by forcing antifreeze through that too. I use the rubber end from a set of outdrive rabbit ears and hold it tight against the top of the sea-strainer...turn on the unit and wait for it to start pulling fluid.
525's are close-cooled, right? No need to drain the blocks; they should be full of conventional (toxic) antifreeze. Just get the pink stuff all the way through the raw water side - pickups, strainers, coolers, heat exchanger and headers. I think you can do through earmuffs; just wait for pink to come out the tailpipes.
Don't forget fuel stabilizer (run the engines long enough to get it into them) and fogging oil.
Or if you want you can just pull your blue plugs on the exhaust, seawater pump, and oil cooler. I believe the heat exchanger will drain through those, I don't think the exchanger has it's own plug.
