how should I remove painted boat name from transom >
Old 05-31-2009 | 09:03 PM
Rambunctious's Avatar
Default how should I remove painted boat name from transom
asside from all of the Nautical superstition of renameing a boat
how should I remove a painted name from the swim platform of my 336
sand
chemical strip
need to get new name on and hailing port as it is a coast guard registered boat
thanks
Ramb
Rambunctious is offline
Old 05-31-2009 | 10:16 PM
Soak a rag with oven cleaner and see how well that softens it up. Or you can wetsand it off.
I ended up paying my detail guy a couple hundred to wetsand the old name off both sides.
handfulz28 is offline
Old 05-31-2009 | 10:22 PM
jayboat's Avatar
Squirt the oven cleaner directly on the paint and let it sit for a few minutes. Use a plastic pot scrubber to help break down the paint. Wipe off the goo with paper towels- don't let it run down onto stripes, bottom paint, etc.. Repeat until done. You may need to wet sand to remove the ghost- depends on how obvious it is and your level of tolerance.
If the oven cleaner leaves some yellow residue on the gelcoat, wipe it with some bleach on a rag.
Roostertail does not lie.
NAPLES IMAGE Photo Galleries
jayboat is offline
Old 06-01-2009 | 07:08 AM
FRMULTR's Avatar
Burnin' Love
I have successfully used the oven cleaner method on one of my past boats but, that was a painted name on a gel coated boat. I be careful if your name is paint over paint.
FRMULTR is offline
Old 06-01-2009 | 09:09 PM
Registered User
Acetone and a plastic pot scrubber also worked for me. I aslo had to have a detail guy wet sand, buff, and polish the area after completing this method. Looked great!
redwenvy is offline
Old 06-02-2009 | 08:28 AM
From: A tree somewhere in the woods in Clarcona Fl.
On the tourpacks of motorcycles (fiberglass) we used Eazyoff oven cleaner and lettering/pinstripes etc. came right off.
Slick02 is offline
