Too bad I missed it Saturday! I'll probably catch up in a couple of weeks.
Originally Posted by kjm5125
(Post 2921852)
3 Attachment(s)
I know this tread has been cold for over a year, but I could'nt resist reviving it after this last weekend.
First off I am proud to say I had two great summers ('09/'10) with out any issues with my boat. Burned a ton of gas though, doing very few speed runs(money's getting tight) but driving all over the place. I picked up a set of labbed 36p Bravos(kinda beat up) in the spring, ran them for a weekend but I wasnt impressed with the cruising speeds. I did a speed run with them right before pulling the boat for the Weiner run out of Cleveland the next weekend. The boat pulled to 101mph, started to chine so I laid off. I was also on fumes so we just put it on the trailer. Before putting in for the poker run the following weekend we made up a jig using a old prop shaft and cut the diffusser rings off the 36's(my stock 34's have no diffussers). The diffussers give stern lift and amplify my chine walking. Anyway, this turned out to be a big issue with the 36's because I couldnt get on plane with them unless the water was perfectly flat. I put the 34's back on, had a great poker run and ran those untill this past weekend. Now to the good stuff. I ran the 34's hard a couple times, a little conservative on the drive trim, a little tab, hit 100mph a bunch of times thru out the summer, and was pretty happy. Since I was pulling the boat this weekend for the season, I fiqured I would try the 36's one last time(and I'm glad I did). In 1 to 2 ft short waves in the middle of Sandusky Bay, 1 notch of tab and 5 in the drives I pulled a 104mph run. Looped around and did another run. No tab, 6 on the drives, and I pulled off a 107mph blast on my limiters at 6000rpm. I was floored. Did another 106mph run today before putting it on the trailer. I was happier then a clam. LE |
Originally Posted by LAKE EFFECT
(Post 3222367)
First off I am proud to say I had two great summers ('09/'10) with out any issues with my boat. Burned a ton of gas though, doing very few speed runs(money's getting tight) but driving all over the place. I picked up a set of labbed 36p Bravos(kinda beat up) in the spring, ran them for a weekend but I wasnt impressed with the cruising speeds. I did a speed run with them right before pulling the boat for the Weiner run out of Cleveland the next weekend. The boat pulled to 101mph, started to chine so I laid off. I was also on fumes so we just put it on the trailer. Before putting in for the poker run the following weekend we made up a jig using a old prop shaft and cut the diffusser rings off the 36's(my stock 34's have no diffussers). The diffussers give stern lift and amplify my chine walking. Anyway, this turned out to be a big issue with the 36's because I couldnt get on plane with them unless the water was perfectly flat. I put the 34's back on, had a great poker run and ran those untill this past weekend. Now to the good stuff. I ran the 34's hard a couple times, a little conservative on the drive trim, a little tab, hit 100mph a bunch of times thru out the summer, and was pretty happy. Since I was pulling the boat this weekend for the season, I fiqured I would try the 36's one last time(and I'm glad I did). In 1 to 2 ft short waves in the middle of Sandusky Bay, 1 notch of tab and 5 in the drives I pulled a 104mph run. Looped around and did another run. No tab, 6 on the drives, and I pulled off a 107mph blast on my limiters at 6000rpm. I was floored. Did another 106mph run today before putting it on the trailer. I was happier then a clam. LE I am happy for ya pal! I wish I was on it, but I am having fun in Cali!!! That is amazing speeds for the boat, I would love to know how much HP it really makes and see what it does when you get the props worked....maybe a little more in her??? not that 107 isn't amazing as it is!! Congrats bud! LJ musta been blowin the waves for ya! |
Now the winter wont be so long.
LE |
(Post 3222378)
LE Yea...maybe i will hit 67 when we pull mine!!! |
LE,
Congrats! Glad to see that it's been a great set-up with no issues for you! That is an awesome number and for sure the fastest 353 Formula out there!!! How bad was the chine? I remember just getting over 90 and having the same issue, but I might have been over triming a little. It went away after I knocked the drives in a touch without shaving any speed. No difusers as well. I tuned mine back a little over the last two years as well, but am still able to pull a solid 90 anytime wih the props turning out and just the 5 blades... Dave |
Originally Posted by axapowell
(Post 3222569)
LE,
Congrats! Glad to see that it's been a great set-up with no issues for you! That is an awesome number and for sure the fastest 353 Formula out there!!! How bad was the chine? I remember just getting over 90 and having the same issue, but I might have been over triming a little. It went away after I knocked the drives in a touch without shaving any speed. No difusers as well. I tuned mine back a little over the last two years as well, but am still able to pull a solid 90 anytime wih the props turning out and just the 5 blades... Dave Need to get out here next summer dave...go for a ride with scott!! |
dude thats moving in a formula:grinser010:
(Post 3222367)
I was happier than a clam. Sounds like a good reason to post up. Great job. |
| All times are GMT -5. The time now is 04:16 AM. |
