-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   496 HO won't do more than edle and miss (https://www.offshoreonly.com/forums/formula/212800-496-ho-wont-do-more-than-edle-miss.html)
bolson 07-12-2009 10:32 AM
Looking for answer to help me get my 353 running.
I have 496 HO and it will not do anything but idle and it missis on more then one cyclinder?
Compression is at 150 on all 8 and plugs and fuel is ok. No codes show up on merc code reader all ok,fuel pressure,water pressure. What can a backyard guy do next.
selpel 07-13-2009 09:44 PM
Originally Posted by jwheels629 (Post 2909397)
try distributor caps and rotors, the factory ones are white metal not copper, might just work !!!
On a 496??????????? Crank triggered no distributor!:cool-smiley-011:
Audiofn 07-13-2009 10:07 PM
Change your fuel filter. Are you sure the fuel is good? Maybe hook up a small pony tank to test.
Knot 4 Me 07-16-2009 10:34 AM
Are you just checking fuel pressure at idle or are you checking it as you are attempting to come on plane under a load? You could have a bad booster pump. Also, some 496's had a in-line automotive type fuel filter between the tank and booster pump. These are notorious for clogging. What year 496?
