I need alternator help
Where is the best place to buy s new alternator?
My first time out this year was at Cumberland last weelend and while checking things out on the hose before I went I could tell it was toast. Ran off the batteries for a couple days by only starting it no radio etc etc. It was reading between 10-10.5 volts on the gauge and the gauge has always been dead on and the lights were dim at night while running and it seemed to get lower at speed Its a 454 ..... what alternator is it? (it has had some type of automotive alternator in it for 10 years,,,, it know its not good but its lasted) thanks PJ |
Try ebay
DB electronics alternators they rank 5 stars in my book |
You NEED to get rid of the automotive alternator. If god forbid it does cause an issue with a fire or explosion you may not get insurance to cover it. You can get marine alternators cheap enough from either Ebay, West Marine or Napa even
do I need the standard 3 wire or the one with the tach lead etc..
take it to a good quality elestrical rebuilder . they can repair it and or even up grade the internal to produce more amps and they should be able to also make sure everything is marine rated . at least the shops around here can
Audio i was wrong it was a rebuilt marine in there for the last 10 years, thanks satisfied I ordered one from DB
| All times are GMT -5. The time now is 05:53 PM. |
