382 bench Seat Grab Bars
I'm going to replace the Grab Handles at the rear bench seat. How do you get to the screws/bolts? I removed the cup holders-no luck. I tried through the side compartment-no luck. ??????
I took mine out awhile ago.......side storage rear piece comes out. If you can't see the 2 bolts then remove the flat starboard piece you see up in there. Then you will see those 2 bolts I mentioned. (I know they are there, just can't remember if I had to remove that section to get to those bolts.)
