-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Formula Logo & decals (https://www.offshoreonly.com/forums/formula/21685-formula-logo-decals.html)
ctpsclark 04-05-2002 10:25 PM
Am trying to find if anyone (Formula or other) makes the Thunderbird on the port and starboard stern of the F272 model in Stainless Steel. I am frustrated by the cheapo's of plastic & chrome. Am told Formula does not make one, but cannot believe it.
Thanks.
Audiofn 04-06-2002 12:41 AM
I have a guy with a CNC machine willing to do it for us. I have a set of new plastics that I can give him. We just need to figure out how to hold it on :D:D
Jon
ctpsclark 04-06-2002 07:45 AM
Formula logo
Thanks Jon,
Three S. Steel skrews would do it--one in each wing and one in the middle of The "Bird". #8 size same as for port holes would work. Can you get a price on job? Metal should be 316 grade S.S. Probably !/8" would be thick enough.
I will put them on a 1986 F272---not sure if all years are the same size. Can get a plastic one to your guy if yours is a different size. Or, I can measure wing tip to wing tip, etc and send that. Let me know.
Thanks again,
Cliff
Audiofn 04-06-2002 08:48 AM
Measure Tip to tip and I will compare to what I have. I would be suprised if they are different. When I got the plastic ones they did not ask me whe size I wanted.
Jon
ctpsclark 04-06-2002 05:34 PM
Formula logo
Jon,
The Thunderbird is 6 1/2" wing tip to wing tip and 3 3/4" from top of bird's head to bottom of tail feathers.
Cliff
Audiofn 04-06-2002 10:47 PM
Come on let me see ya shake your tail fethers :D
ctpsclark 04-07-2002 07:36 AM
Formula logo
Actually, shook them for the first time with repower. Yesterday was launch day!
Audiofn 04-07-2002 10:28 AM
How did she run?
ctpsclark 04-08-2002 07:27 AM
She ran well. I have a pair of 5.2's (250hp). Replaced the port engine two years ago and starboard this winter. Could have done a rebuild on the starboard, but am building a new ferryboat up your way (Blount/Barker, Warren, R.I.) and plan to use Formula to run up to the shipyard some this spring---didn't want to get into those waters with any questions about the engine.
Did not push her in first run, but liked how everything felt in short trip. Also am trying aluminum full props vs cleavers (S.S.), both 3--blade. They give MUCH better low end acceleration (0-30 in 6.6 vs 8.5) and smoother mid range cruising. Probably give up a knot, or two at top end, but that's not critical for me. Both previous engines were originial 1986's---got the boat used in 1995, so they didn't owe me anything.
jrocket 04-08-2002 12:07 PM
I'm interested in this also! Have you also considered the the Formula on top starboard @ the transom? jrocket
