Gas Smell
Old 04-08-2010 | 09:50 AM
  #41
Originally Posted by BiLLyLaurianO
Well Shes Done.
Congratulations! And good luck!
Klas233 is offline
Old 04-09-2010 | 12:18 AM
  #42
Audiofn's Avatar
Charter Member #232
Originally Posted by Klas233
That's not quite true - where I live insurance companies explicitly recommend using stainless steel over aluminum for gas tanks (and some even require it I believe).
You must not be in the US? In the US Coast Guard regs do not allow it. I don't know why but I was going to do stainless for my tank tell I read the law.
Put your best foot forward!
Audiofn is offline
Old 04-09-2010 | 06:35 AM
  #43
Yeah, I'm in Sweden. Interesting how safety regulations can be so different in different places. This country is usually known for its (exaggerated?) focus on safety issues (this is where the seat belt was invented...) - but then again it is a major steel-producing country too so who knows the reasons for the different recommendations and traditions behind them.
Aluminum appears much more common in the U.S., but checking the US Coast Guard's Boatbuilders' handbook it seems to me that stainless steel isn't prohibited in the U.S. - but if it is used it may not be encased in foam, see here:
http://www.uscgboating.org/regulatio...rds_parta.aspx
Either way, avoiding foam around any metal tank makes sense to me now after having seen the corrosion that was caused by wet foam surrounding my (aluminum) tank.
http://raffinaderiet.com/Formula/htm..._gas_tank.html
Klas233 is offline
Old 04-12-2010 | 09:02 AM
  #44
Well maybe someone can help me. I got tank in and all fires up ect. My new problem is the cuddy had gas still in it. I dont see a drain. I notice my floor is cracked after ripping up cuddy and finding a puddle of old gas n water mix
MY HELPER
BiLLyLaurianO is offline
Old 04-12-2010 | 09:05 AM
  #45
When you step in u can here the water and see it come threw the crack. I wonder if I can hole saw a hole and stick wet vac in there?
Next the bbc 223ls will be for sale to buy a bigger formula.
Old 04-13-2010 | 10:16 PM
  #46
Audiofn's Avatar
Charter Member #232
You can try the hole saw deal but I don't see how you can get away with not cutting out the floor. Sorry to be the bad news guy.
Audiofn is offline
Old 04-13-2010 | 10:22 PM
  #47
offthefront's Avatar
was that a bomb or what? ......lucky you found it
offthefront is offline
Old 04-17-2010 | 06:25 PM
  #48
sleek1's Avatar
If there is a gas/water mixure, I would not wet vac it out. An electric motor may ignite the gasoline vapor.
sleek1 is offline
Old 04-17-2010 | 09:09 PM
  #49
Thumbs up
Well I spoke with Scott from formula.What awsome guy. He dug up old plans so I no were to cut n drill n what ammount of foam to use. Im takin a break for a month then will go n pull boat from storage n work on it .I am really impressed the customer service u get from formula even though boat is a 1987. I will always own one just for that its amazing!.
Old 04-18-2010 | 08:59 AM
  #50
jeff32's Avatar
yep!
jeff32 is offline
