Loss of speed >
Loss of speed
Loss of speed
Old 12-01-2009 | 06:49 PM
Default Loss of speed
Hi I have a 242ss formula that has loss speed. I am running a rebuilt 330hp at 3000Rpm my speed has gone from 30 to around 25mph and 4000rpm around 35-38 I am running a mirage 21 pitch prop. I feel like I have lost about 5-9mph when I pulled the boat out the drive was full of barnicles would that do it? The boat tops out at 4100rpm I was thinking of getting another prop with 19inch pitch to increase top speed.
Tony
tonyviscione is offline
Old 12-02-2009 | 06:39 AM
C_Spray's Avatar
Diamond Member #001
Clean running surfaces (including the outdrive) are essential to good performance, even more so as the speed rises. Clean everything off and try it again.
C_Spray is offline
Old 12-02-2009 | 06:09 PM
masi242's Avatar
Your engine should run to about 44-4600rpm with the prop you have are you sure the engine is running fine. Max speed with your set up is about 50-52mph. Clean it up the bottom and outdrive and try again.
masi242 is offline
Old 12-03-2009 | 10:53 AM
yes a crummy bottom and drive will scrub speed, even more then you may think
88242LS is offline
