ol school 272 >
ol school 272
ol school 272
Old 12-13-2009 | 10:25 AM
Default ol school 272
Does anyone on this thread run an early 80s smallblock 272LS.Im restoring an 84.
Scorpion Paul is offline
Old 12-14-2009 | 11:35 AM
We did a lot of work on one for a friend of mine it is a 84 LS as well, nice boat. Good on fuel but uses a lot of beer!!!!!!!
BOATMAN302 is offline
Old 12-14-2009 | 04:24 PM
I have a 83 272 with small blocks. I pulled motors and transon assy 13 yrs ago to paint bilge and look at things ect. Put corsa
captain's call exhaust on. Wife won't let me upgrade because boat has been a good one. What questions do you have?
H2OWRENCH is offline
Old 12-14-2009 | 05:58 PM
What kind of speed do you get? what props do you use? Are the engines stock. Does yours have k planes if so how does it effect the ride. the gimbals on mine were rough just picked up a nice freshwater set. Are your drives counter rotating. How are they set up, rotating out? thanks Paul.
Old 12-14-2009 | 09:08 PM
Brought the boat with 260hp. the motors have lasted 13yrs plus the owners hours before me. Did run 60mph but now 56.Cleaver 21props, not counter, bennett tabs. Friend has same boat 300hp tempest motors running 70 on good day. Had the chance to go counter but rode on two other boats with counters and saw little to no difference. I have a spare drive to fit either side and did not want to worry about finding props.
Old 12-15-2009 | 06:23 AM
Thanks for the info mine has 330hp vortec engines that are being massaged right now. When I talked to Formula they said 62. but also heard that wasnt realistic on such a heavy boat. Mine has counter drives with merc mirage 21p props.
Old 12-16-2009 | 09:06 PM
Paul, do not understand why 62 is not realistic. 300 tempest motrs were pumped up. My motors have center bolt valve cover head which raise comp ratio a little. 5800lbs dry is weight. the hp to lbs ratio verses big blocks/TRS is going to help. Small hp gains show more. 272 did 57mph w/260 when new if I remember. Anybody else have input?
Old 12-17-2009 | 09:57 PM
In 87 a buddy of mine bought a new Cobalt Condurre 27 set up the same way it could hit 60 under the right conditions. Probably a reliable 55 all the time. Through talking to folks I heard the 272 SR1 big block version was a 70mph boat. I would be thrilled with 65. Im hoping for 400 ft.lb. of torque out of the engines. My 30' Scarab had 330/454s with trs drives that was an honest 65mph boat. Just fishin for info from someone who has a proven setup.
Old 12-18-2009 | 01:14 PM
my 87 272 i had ran 59.9 GPS with 260's only upgrades were MSD coils K&N arestors and locked timing @35 degrees. 648 HRS
4800 rpms spinning 23 Mirages was 59.9
3500 cruise was 40.1 GPS
Car Biz is offline
Old 12-18-2009 | 10:15 PM
hey car biz do you mean no advance straight 35 off the pick up only?
