Formula 255 Liberator >
Old 02-14-2011 | 07:14 PM
  #31
i have thru hull now on my liberator. so far they sound pretty *****in' can't wait to open it up this summer on the Niagara. Drilling the holes is how my father found the transom rot. that wasn't fun replacing it all. but now its done and is the better for it.
bowlner is offline
Old 02-16-2011 | 09:40 AM
  #32
bowlner, def would like to to see/hear the new pipes!!! Anyone have advice on a 23ft webbcraft enterprise? 454/thru hull/bravo 1 and the boat actually is water worthy with a decent hull and interior... $1500 opinons guys??
machloosy is offline
Old 02-16-2011 | 09:35 PM
  #33
bowlner is offline
Old 02-16-2011 | 09:46 PM
  #34
there are my new exhaust, the tips come out pretty much where the swim deck sat. so had to raise that. everything is above the waterline and sealed with 4200. so no rot. plus its a new transom!hah
bowlner is offline
Old 02-17-2011 | 07:13 AM
  #35
Dude sweetness! Thats good lookin and somethin to dream about!
Old 02-27-2011 | 09:58 AM
  #36
Here is my update for Feb 27, 2011.
I had a hell of a time removing the outer bell housing or "skull" on the starboard drive. I was never able to remove the port side pivot pin bolt and ended up cutting it out with a sawzall....easier said than done!!! Once I got it apart I found that the mounting flange for the u-joint bellows on the transom assembly was completely corroded away at the bottom. There is a kit made by Sierra that includes a special PVC ring on a bellows along with epoxy sealer that can solve this problem but based on the way I plan to use the boat I decided to not cut any corners and go ahead and replace the transom assembly.
Replacing the transom assembly requires removing the engine to get to the inside of the transom assembly. I could use an Alpha I assembly but then I would need to replace the steering connection as well as the Y-Pipe. I hunted down and found a fresh water clean No. 1 transom assembly complete with trim rams, skull,gimbal ring,etc. The gimbal ring is tight so as to maintain steering control at spec. This is a perfect match for my original and will bolt up perfectly. This assembly is set up with the later model rams that allow 3 deg more of trim than the older models so I am good to go.
We are pulling the starboard engine this week, swapping transom assemblies as well as installing new u-joint and shift bellows along with new gimbal bearing, water pump,etc.
All of this is a bit of a pain in the a$$ but is the kind of crap one encounters in restoring a 32 year old boat.
Stay tuned...
sprink58 is offline
Old 03-01-2011 | 04:42 PM
  #37
Geez sprink, how the hell did you find another transom assembly??? I can't imagine trying to track down a 32 yr old transom ha. It'll be so cool to have the boat done right! I'm seriously thinking about grabbing the webbcraft enterprise and swapping in the 454/bravo next winter. Thoughts?
Old 03-03-2011 | 03:39 PM
  #38
If you're talking about $1500 with the 454/Bravo? If so and you can spare the $$$ do it...you will never touch that price for even the Bravo drive & gimbal/transom assembly. The 454 Bravo will be SWEEEET in your Formula. You would be lucky to find that engine/drive package for 3x that price!!!
If you don't buy it...let me know & I'll put it in my brother's F3!!!
sprink58 is offline
Old 03-05-2011 | 07:46 AM
  #39
Crazy thing is thats its a 454/bravo... AND a whole boat lol. She's even got the trailer under her and its a nice HD with surge brakes fresh tires etc... Guess its time to go get her. I'll let ya know when I do!
Old 03-07-2011 | 06:01 PM
  #40
Stay tuned...
Things are moving along...got a little cleaning to do but not bad for 32 years.
Serial numbers make this a non-vortec 2006 Merc crate engine
...it used to be yellow...transom is rock solid.
...stay tuned.
sprink58 is offline
