242LS Speaker placement options
The problem with open air "free air" subs is that they still need to be sealed from the front. When the rear waves hit the front waves they cancel each other out and you loose volume. Putting them under the seat really won't work. There are tons of passages that will allow the back waves to hit the front. All free air means is that you don't need a box but the front and rear still need to be sealed off from each other. They work in cars but IMO not real well in boats, unless you build a giant box.
endeavour, that is something that I have been curious about for a while.... i know that the front waves and back waves cancel each other out.... but as far as the cracks and what not letting the waves through to cancel out... i am having trouble. There is no doubt that some of the saves are escaping from under the seat but can you explain to me how this would be different from a ported box, or better yet a bandpass box (where the port is in the front typically)?? wouldnt those be allowing soundwaves from the rear to encounter sound waves from the front??
My sub is mounted in the port footwell, firing towards the helm. Not sure if its better there vs. under the rear seat, since it's all cheap equipment (came with the boat), but it's much more out of the way and doesn't take up any storage.
