Shift cable getting harder to shift into drive?
FWIW the cable is 16ft and it appears any "33c" cable will work. I measured rather than removing the cable and added a foot to be safe. I came out with 18' with my measurement and it still worked fine, just looped around in the engine compartment a little more. The swap was easy, I taped the new cable to the old and fed it back through to the controls so it was routed the same as before. Went easy as pie, which is uncommon for my projects!
