gas again !! >
gas again !!
gas again !!
Old 07-01-2010 | 11:42 AM
Default gas again !!
We finally pulled boat out last sunday. No leak no smell..
Here is the new problem. When I gave it gas I would get a fuel reading. then back on empty. What could it be. I replaced tank with brand new one. Is the new signal sending different to vdo
BiLLyLaurianO is offline
Old 07-01-2010 | 03:28 PM
I am pretty sure they are different from the new ones today. The ohm range is where they are different.
jmrapp is offline
Old 07-01-2010 | 04:00 PM
the place I got the tank fro said this is what they put in it
reads 240 empty n 30ohms full
What was put in 87 would be of help
Old 07-01-2010 | 05:47 PM
Don't know for certain, but recall the old VDOs go the opposite way, 0-90ohm I think.
The upside is that when you upgrade the dash you won't have to change that sender.
humbler is offline
Old 07-02-2010 | 09:28 AM
My issue now is that they gauge reads full. There is no fuel in the boat. It still reads full when I take off the sender wire on the back of the gauge. Any help?
jmrapp is offline
Old 07-02-2010 | 05:12 PM
ok I just put installed a beede fuel gauge. My boat guy let me borrow and it seems like that may have solved problem.. Im going to park it level and add some gas.. I will update
Old 07-04-2010 | 03:55 PM
spazboz's Avatar
I'll take a look when I get home. I have the part number of the VDO sender you need for the Factory guage to work. If I recall the correct one is about 80 bucks new.
spazboz is offline
