Formula Fastech 292 Trailer Suggestion >
Old 07-25-2010 | 07:56 PM
Default Formula Fastech 292 Trailer Suggestion
What do members recommend for a trailer?
Tri axle vs tandem axle
Aluminum vs galvanized steel
Thanks.
1MOSES1 is offline
Old 07-25-2010 | 10:24 PM
Expensive Date's Avatar
I tow mine with a tandem axle loadright galvanized.Tows fine but the trailer is ok.May get an aluminum Myco depends how long I keep the boat.So in short tandem is fine and I would get aluminum even if you boat in fresh water.With a steel trailer you limit yourself on resale to only fresh water boaters.And get a Myco.
Expensive Date is offline
Old 07-26-2010 | 04:58 AM
just double the weight of the boat for the trailer capacity and you will be fine....
mookymonkey is offline
Old 07-26-2010 | 12:25 PM
Mine is on a steel tri-axle made by Prestige. Tows absolutely perfect behind a 2500HD Silverado.
4mulafastech is offline
Old 07-26-2010 | 05:02 PM
i have a eagle custom made dual axle steel trailer works great for me
oh6662b is offline
Old 07-26-2010 | 07:38 PM
I have a dual axle steel painted Manning. Tows great, looks great...but I'd get a aluminum next time for sure......
JayFan is offline
Old 07-26-2010 | 09:11 PM
it sounds like i can go with a tandem axle. How close will i be pushing the limit of the trailer with an aluminum dual axle. A dealer told me a tri would be required.
I live in Central ct and would want to tow the 292 to RI on occasion. Would this be doable on a dual?
1MOSES1 is offline
Old 07-26-2010 | 09:31 PM
call Bill at performance trailers in lake george, he will take care of you, tell him sam sent ya, I belive you can get a tandem axle but it better be a custom built with HD axles and you wil be fine
88242LS is offline
Old 07-27-2010 | 07:22 AM
I rather stay local on a trailer. I already received a qoute for a tri...4200 (load rite)...They matched fast loads price.
I think that is the best I am gonna do unless I go used.
1MOSES1 is offline
Old 07-27-2010 | 07:44 AM
[QUOTE=moses0324;3168660]or a tri...4200 (load rite)...
I would not buy another load right.
