Winter Projects >
Winter Projects
Winter Projects
Old 08-13-2010 | 08:19 AM
Default Winter Projects
Hi everyone, I figure to start this forum to tAlk about winter projects and have other members help people in need.
I am going to be doing a good winter project on my 1985 242ls. I have a 350 :/ with alpha and just want to make it purr. So I am doing thru hull exhaust. Straight out the back. But looking at the motor and water line it seems like It can be a little difficult to do. I was wondering If anyone has done this before. Either on a 350 or not. My manifold is tilted down a little and if I run straight hose it seems that it will hit the steering. I have not checked it completely yet because I want to do some research. Also should I put some kind of muffler on it? Yes I want a good sound but also need a little back pressure so it doesn't wear out my motor. Any help from anyone would be awesome. Thank you.
srdrago is offline
Old 08-13-2010 | 09:43 AM
BONDO10's Avatar
Your talking about a winter project in August. What an a-hole!!! Are you going with Chris ?If so I will see you at the Poker Run tommorow
BONDO10 is offline
Old 08-13-2010 | 09:51 AM
Winter comes quick when your in colleg
srdrago is offline
Old 08-13-2010 | 05:30 PM
it'll work. But i think if you have manifolds you'll need 4" risers
P.S. The tips are just above the waterline
Fastereddie is offline
Old 08-15-2010 | 09:31 PM
Very nice. What do you have done to the motor? 350 or 454?
srdrago is offline
Old 08-17-2010 | 10:39 AM
It's a 383 mouse... So far I've got to 56 mph
W a 21p 5 blade. I'm thinking with labbed 3 blade I might get 60?
Old 08-17-2010 | 11:14 AM
I just got the stock 350 (SB) with 17P 3 blade. nothing else done to it. I just got the boat. I want to do through hull, put a manifold spacer to raise the exhaust higher, then ill clear the steering to go right out the back. Going to have to do something about the 4inch tips and the 3inch manifolds.
srdrago is offline
Old 08-20-2010 | 07:32 PM
I just did mine last weekend I have the 242ls with the twin 350's I took the 3 to 4 inch boot and put it on the manifold, then took the 90's that run to the y pipe and cut them before the bend to give me a flange to connect the 4" exhaust hose to and it works fine and sounds a lot better
rjh12904 is offline
Old 08-22-2010 | 10:49 AM
Any pictures??
srdrago is offline
