A/C ???s
Have a gentleman that may be interested in my boat; a question he asked was whether air conditioning could be added, to which I did not have the answer.
I don't believe it is possible, but does anyone know for sure? Boat is a 1992 303 SR1.
Thanks.
Thanks.
Anything can be done with a big enough check book. I considered adding it to my 311, couldnt justify it when resale time comes.
I'm not real familiar with that interior but I added A/C to my 312 a few years ago (and sold the boat 6 months later). I removed the pumpout head and used a portable one that sat on the floor in front of the A/C return vent. Plumbed the lines to the engine compartment thru-hull for water pick-up and discharged the cooling water out the side. The cabinet I built had a vent blowing air to the back AND the front with the controls on the front side so you could reach them without even getting out of bed.
)What unit did you use?
For a portable AC, buy a $100 window unit at Home Depot. In front of the cabin door set a towel and 2 2x4's. Place the AC unit on that lined up and facing in the door. Buy some cheap 4-5 inch thick foam and cut to fit the rest of the doorway. If weather is an issue you can put the cockpit cover on 1/2 way but you must leave an opening for the hot air to escape.
We did this for a couple years, even climbed in/out through the deck hatch instead of over the AC unit (which is possible too)
we go in the cabin quite often to make drinks so access there would be important. i am thinking of a portable unit from Home Depot and using an inverter and placing the self contained unit exactly where yours is up on the side of the bed. guess i would have to create an exhaust vent somewhere?
As a side note, some of those portable units don't cool worth a damn, and you need to have an easy place to vent the hot air.
Be carefull with an inverter, with a typicall AC unit on a hot day you will kill even the biggest batteries in under an hour.
I was going to do an install like T500's did, but the window unit works so well for $99 i decided against it. My next boat will have AC built in
