Put the bird in a nest >
Old 04-15-2012 | 10:42 PM
  #121
PhantomChaos's Avatar
Originally Posted by Audiofn
Well????
The new Kodiac brake rotors and parts had a problem. All new rotors and calipers are being installed as soon as they come in. Not sure exactly what the issue was. Tunes sound good!
PhantomChaos is offline
Old 04-16-2012 | 06:29 AM
  #122
Audiofn's Avatar
Charter Member #232
Well that sucks!
Put your best foot forward!
Audiofn is offline
Old 04-16-2012 | 10:28 AM
  #123
That is a reflection of the tail light on the bottom of the trim tab.
NOW I see it !
RT930turbo is offline
Old 04-16-2012 | 04:27 PM
  #124
Does that one give you the remote still?
Yes the old remote Formula installed works with it and it will work with the new marine remotes too. I have not added any more remotes but probably will. One on the passenger side and one on the transom too.
Old 04-18-2012 | 12:08 AM
  #125
Audiofn's Avatar
Charter Member #232
As for the breaks.... A guy with out an Ipad would have just disconnected the brakes and towed it that way!
Audiofn is offline
Old 04-19-2012 | 12:53 AM
  #126
I've driven it a few times with NO trailer brakes at all, one time in the rain. Not good!!!
The new rotors were rubbing against the bracket assembly for some reason......something about them not being able to hold a tolerance or something with vendors. Replaced with kits that include rotors and brackets, and that was finished today. Hitting the water at Lake Castaic on Friday before noon. Hope all goes well. We have plans to go to Lake Mead a week from tomorrow!
Old 04-19-2012 | 07:44 AM
  #127
Audiofn's Avatar
Charter Member #232
Cutting it close!
Audiofn is offline
Old 04-22-2012 | 10:48 PM
  #128
Cutting it close!
Everything went pretty smooth on Friday. Nothing major to report other than everything worked great. A few adjustments and tweaks to do and we'll be ready. It's been nearly 7 years since I've been to this lake. They took 45 minutes to review the boat and check for Zebra Mussels?
Attached Thumbnails Put the bird in a nest-dsc_1223.jpg   Put the bird in a nest-dsc_1225.jpg   Put the bird in a nest-dsc_1228.jpg
Old 04-22-2012 | 10:53 PM
  #129
Cutting it close!
Jon.........sorry to say, the Clarion 10's sounded bad. I took one off and this is what the problem is. I think one channel is bad on the amp too......so, it lasted quite awhile but it was time for new like everything else!!! :thankyouth ankyou:
Attached Thumbnails Put the bird in a nest-bad-bass.jpg   Put the bird in a nest-boxes.jpg   Put the bird in a nest-amp.jpg
Old 04-23-2012 | 03:54 AM
  #130
RedDog382's Avatar
Hard to do that job sporting a woodie ... looking great Nort!
RedDog382 is offline
