-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   419 sr1 Formula (https://www.offshoreonly.com/forums/formula/242030-419-sr1-formula.html)
born free 11-06-2010 08:35 AM
419 sr1 Formula
I have a 1996 Formula 419 sr1 with triple 502 mag mpi. (not a stepped hull) I run 25 pitch 3 blade mirage props for a top speed of 75 mph at 5100 rpm. I am putting in 3 prochargers M1sc with 5% boost. My question is what speed can i expect out of this set up and which is the best possible prop and pitch for top end performance.
An advice would be helpfull. Thank you.
pokerrunboats 11-08-2010 06:23 AM
Expect 4-6 MPH Top Speed ( not gain) with blown engines :evilb:
These old engines will have to be rebuilt prior to supercharging :drink:
The 419 SR 1 likes 4 or 5 blade props in combination with Imco
3 `rise extension Boxes and some more HP
born free 11-08-2010 02:50 PM
Motors have 150 hrs on them. Done head gaskets ect. Not planning on stripping the motors down as i have 180 psi com. Had the boat for a few years dont get out much in it so motors are good to go.
485 hp on last rebuild 6 years ago. I should be seeing 700 hp with procharging and 5 or 6 pounds boast i hope. I was thinking of 4 blade hydro 29 pitch props to start off. Maybe to much maybe not have to wait till spring to test. Snow is starting to fall up here.:eek:
masi242 11-09-2010 06:44 PM
Just be gentle on your drives, Bravos I assume.
pokerrunboats 11-10-2010 11:28 PM
419 Sr 1
5 Attachment(s)
419 SR1
started as TWIN engine boat
twin 465 - 55 MPH
twin 465 with Pro Charger 70 PPH
lasted 10 hours only
Triple 496 HO `s 72 MPH
Triple 496 HO `s upgraded to 525 HP each 79,8 MPH GPS
Imco Extension Boxes 3 `rise
Bravo 1 lab finished props 30
Boat planes on any 2 of 3 engines with the 30 `props
Go with Imco SCX drives if you exceed 600 HP
just my 2 cent
born free 11-11-2010 03:37 PM
wow never knew these 419 were offered as twins. You could put some big power with staggered setup. Why did the orginal motors fail with prochargers.:eek:
