-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   engine hatch lift assembly (https://www.offshoreonly.com/forums/formula/242673-engine-hatch-lift-assembly.html)
ddabal 11-18-2010 07:02 AM
I have a 87 24ls. bought it last year. the entire engine hatch lift assembly was missing. i would like to get it working again. finding the actuator is no problem, the part i really need is the actual bar
that attaches to the underside of the hatch. i believe it was either aluminum as stainless and sort of U shaped. anyone know where i can find one, or is there another route i can take. thanks
Dennis
masi242 11-18-2010 05:17 PM
That may be hard to find, but if find a local shop that has tubing and can bend it you will find.
endeavour32 11-18-2010 10:22 PM
it's stainless!
Audiofn 11-19-2010 03:58 AM
Is it a bar or a bracket? On my 311 and every boat I have seen of its vintage they are brackets. I can get you pictures of mine and you can probably fab some stuff up or have it made up for you. I would think that even the guys that make/sell the rams may have brackets that will work.
ddabal 11-20-2010 06:37 AM
Hi
its the bar, stainless tubing im told. the brackets are the only thing that are still there. a pic would be great, maybe i could have it made.
thanks
I hope this is the proper way to respond I'm new to this site and still trying to figure things out
Audiofn 11-20-2010 07:51 AM
Does the lift fit in the center or one side of the hatch?
88242LS 11-20-2010 09:43 AM
on a 242ls it would lift from the side
ddabal 11-20-2010 02:41 PM
off to the right side of the engine, seems a bit funky to try and raise such a heavy object from the side like that. the center lift sounds like a much better system.
dd
88242LS 11-20-2010 02:44 PM
dd
it is but thats how they did it back then
formula206ls 01-05-2011 11:00 PM
A center lift would also be smack dab in the middle of the plastic Formula mirror!
