-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   88 242 question (https://www.offshoreonly.com/forums/formula/244835-88-242-question.html)
whipplenut 12-31-2010 12:28 PM
88 242 question
Hi everyone
I got a 242. My question is I am in the process of building a new engine I had the 454 mag in it. I am buliding a 540 with around 645-655hp I am wondering if anyone one the board can tell me what speeds I will see out of it? It was to slow with stock power. I have a bravo drive which is going to be upgraded. I will post pics also soon
Baja226sport 12-31-2010 03:52 PM
There is a 242 on ebay for sale right now with a 502 running a small blower. The guy said it is making 600 hp and at WOT it is running right at 70 mph. So if this it true then I would guess 72-74 mph???
Again that is just a guess as I do not know the guy personally so I don't know if his boat is actually 600 hp or 70 mph....
masi242 01-02-2011 02:50 PM
I would agree with that low 70-75mph would be right. There were a couple on here that made over 550hp if I remember right and did just about 70. Remember that is a good speed for a hull made over 20 years ago, low x deminsion, 24 degree hull and a hook in the hull built in. This boat should ride very nice.
86242ls 01-03-2011 01:59 PM
I have a 242 ls with a 509 bbc, going thru an alpha, and it has seen 75 on gps with 1/4 tank of gas and no gear with a 23 pitch mirage plus with a blue printed bottom, alpha FTW!!!!!! its faster than my buddys 271 with a 502 and fathers 302 sr1 with 496s.
Baja226sport 01-03-2011 02:34 PM
What kind of power are you making?
chewymalone 01-03-2011 05:17 PM
Built a 496 making 620HP in mine back when I had it. Top end was 71 on GPS with Bravo X upper and Imco XR lower. Had the hook taken out of the hull. Cruising speed improved but top end did not.
Monaco20 01-03-2011 05:57 PM
This is rather interresting, I know of verified speed of 61+ mph with a stock 502 mag Bravo1. I am not sure if that engine used to have 415
or 425 hp. Then you increase the horse power with 50% to 620 hp and a better drive line. The result is 10 mph???? I would have been rather disapointed.
What kind of power to reach 80 mph++`????
masi242 01-03-2011 06:40 PM
Chewy, I knew someone had taken the hook out of the bottom, so know real change. That is a great step up to a TG maybe some day:drink:
Baja226sport 01-03-2011 07:27 PM
Alot, unfortunately these hull are notoriously slow!!!! Most of the earlier formulas are.
People say Bajas are junk but all I have owned were pretty easy to get moving with decent power.
I am buying a Formula 272 though. I feel that the lack of speed is made up for in solid quality!
86242ls 01-03-2011 07:58 PM
mid 500's
353Formula 01-04-2011 08:42 PM
looks like its time to build a 700sci for my 271!!!!!!!!!!!!!!
masi242 01-06-2011 06:09 PM
86242, Do you have seperate cooling raw water pump for your 509 or do you just use the alpha.
86242ls 01-07-2011 04:34 PM
just using the alpha for now, I plan to upgrade to a bravo setup at some point $$$$....
86242ls 01-07-2011 04:35 PM
Maybe then it will break the 70mph mark lol!!!!!!
353Formula 01-08-2011 08:38 PM
Its already broke that...
endeavour32 01-11-2011 09:34 PM
I agree with the others that you should see low to mid 70's. I have around 525-550 hp and I see 65 mph in chop with a mirage 21 non plus that is not in perfect shape.. With the prop dialed in I should be around 67-68. Great boat, it just takes a lot of power to get moving fast.
4mulanut 01-18-2011 07:55 PM
86242ls Where do you run?
86242ls 01-20-2011 03:45 PM
Hillbilly heaven FOX LAKE, IL
4mulanut 01-21-2011 07:17 AM
Hey I run out there to. What colors are your boat? I have a 233 with a 632ci in it . with a bravo The best I can get is 77 gps. I did the transom change over from alpha to bravo after I wiped out two alphas. The boat was scary I did a full hydraulic setup with a box on it now. Its much better
endeavour32 02-01-2011 08:51 AM
What rpms are you turning with that 23 pitch prop. IMO it takes a lot more power than mid 500 to get to 75 in a 242. I have between 525-550 hp and I'm only getting 65 mph via gps?
Waterdogs 02-01-2011 08:44 PM
I used to see 67+ on GPS speedo with a labbed bravo 24P, 4 adults and a half tank. I'm told the motor is putting out just south of 500HP, but never saw a dyno.
